CC Build 514 Issue
Curious to learn whether anyone else is experiencing the following issue when attempting to create flipped fillets on a regular rectangle in CC #514… the second I try to adjust the radius of the fillet, the vector automagically adds full circles to the two uppermost fillets!
I can’t seem to de-select the unwanted additions to delete them - they are already “grouped” to the main rectangle, and cannot be ungrouped…
(Forgive the wording on this - a buddy wants this for his girlfriend’s birthday! :man_shrugging:)
Seems to not happen in 517:
flippedfillet.c2d (5.1 KB)
Thanks, Will - I didn’t realise there was (another!) new update… I’ll download it accordingly and retry.
Still getting 'em - even with 517 installed… (PC = Win 10 Pro 64-bit OS)!
Screenshot (408)|690x389
Please post your file.
Does the one I posted above:
https://community.carbide3d.com/uploads/short-url/17bmi8SHvZyfw9bBMorg9fOn0WJ.c2d
exhibit this behaviour when opened on your computer?
Yes - same behaviour exhibited on your file (try resizing the rectangle to an arbitrary height - I adjusted to 4" tall… the “Mickey ears” popped right in!
(Here’s your very same file re-attached… the only adjustment I made was to the height of the rectangle (from 3.x" high to 4" high))
Flippedfillet.c2d (7.6 KB)
The thing is, when I change that file to the dimension it had before, 3.5433 — they go away:
Doesn’t show up at 3.8" high, shows up at 3.81" high
Filing a bug report now.
Weird! (I’ve never experienced this before now, and use this function often!)… Thanks for your help, sir! :+1:
I see the same thing in 517. If the radius is changed to 0.649" or 0.651" it is fine. Very strange indeed.
