There are times when simulation of the Advanced VCarve of text can take 5 minutes or more, even on a i9 with 32Gig and nothing else running. That’s bad enough…but if you need to make an adjustment to another part of the design, and then want to see the simulation again, you have to wait for that calculation all over again - even if the toolpath didn’t change.
The suggestion is for Advanced VCarve because it seems to be the most costly, however, for performance, this suggestion could be for all toolpaths: Cache the results of the toolpath after the first calculation, and if the toolpath doesn’t change within a session, use the cache rather than recalculating.
