CC question - selecting multiple designs elements
I have a load of circles on object.
I cant seem to select more than 1 of them as I want to modify the radius.
Is this possible ?
Drag-select, or shift-click on geometry to add (or remove) it to/from the selection.
No, that does not work.
I can select multiple (identical circles) but once I have more than one selected I cannot modify the radius.
Rather than modifying the radius, offset them by an amount which makes them the desired diameter — unfortunately, they cease to be circles, but they’ll be the right size.
ok, thanks, will look at doing that.
hi Will
Just to clarify.
I have an 11.5mm circular recess.
In the centre I want an 8mm hole.
So I assume CC works out the correct size using the specified bit chosen in toolpaths ?
So if I put an offset 1.75mm that would be correct ?
Yes, for an offset think in terms of radius, so:
5.75mm - 4mm == 1.75mm
