Hi,
CC is an excellent tool for small things. I ran into a small problem. I wanted a hole 4.8 mm. But in CC decimal number 4.8 has not supported. Only 4mm or 5mm
For Central Europe is a Comma as decimal separator.
Input box in CC has hard-set format…0.0 / zero point zero
But the validation rule is derived by regional setting …0,0 /zero comma zero
As a result, you can not enter decimal numbers
You can add to code something like: … inputControl.value.replace(",", “.”);
or merge validation with format ?
Thanks
Michal
