sixstring
(Chris Kwiatkowski)
September 7, 2021, 1:36am
1
Hey all! Is there a way to change a CM file back to a CC file? I normally save all of my CC files in a separate folder. I spaced on a few of my files and didn’t but I have the CM files. Anyway to convert them back? It would save a lot of time.
Thanks!
WillAdams
(William Adams (Carbide 3D))
September 7, 2021, 1:56am
2
There is a 3rd part utility which will sort of get the geometry out of G-Code files, G-Code Ripper from Scorchworks:
https://scorchworks.com/Gcoderipper/gcoderipper.html
sixstring
(Chris Kwiatkowski)
September 7, 2021, 1:27pm
3
Thanks Will!
Will I be able to load the converted file into CC and see my original design or is it more convoluted than that?
WillAdams
September 7, 2021, 1:47pm
4
You will get the toolpaths, and possibly an offset from that — you’d probably then need to offset by the tool radius and adjust if need be.
system
(system)
Closed
October 7, 2021, 1:37am
5
