Mine defaults to 13.005mm. I would like to change it to 1mm. Is there a way to do this?
Create your own folder in the tool library and create your tweaked version of the tool.
Thank y’all for taking time for me. I’m seeing it in the “Max Depth (D)” edit box. Is there a way to change the default?
Maybe edit the .ini file for preferences?
Could not find an ini file. Turned on hidden files and folders. Great idea…
Help | About | Open Data Directory
Mine is at:
C:\Users\willa\AppData\Local\Carbide 3D\Carbide Create\settings.ini
there are three entries for depth — if one has 13.005 assigned to it, try editing that.
