I am cutting thin aluminum sheets. In order to get a clean cut the tool path needs to move clockwise (CC calls it “Inside / Left”). Is there a way to create a tool path for Outside / Left in CC?
Thanks!
Thanks!
Not really.
You could offset the path and then do an Inside / Left path which would cut the outside.
That is what I have been doing. Thanks for the quick response!
