Changing default tool in toolpath
how do i change the default tool to a 1/16 endmill
Click the edit button under the default tool…
Then click the select tool button when the edit tool box opens.
Select the file where the tool is located and click on it. the tool info will then show and you can click the OK button.
That window will close and the edit tool box will show the bit selected then you can change the tool parameters if need or leave it as is then click the ok button.
your tool will then be loaded.
Anthony
