The local K mart was going out of business and my girlfriend decided to get this little kitty dish to split soft cat food for the two furry little felines.
Added some cherry.
If anyone wants to make one here is the F360 file. Attached are the two gcode files meant to be used with a 1/2" 2 flute straight router bit. The wood was 0.85" thick. I did not cut with tabs, so use the hot glue or double sided sticky tape trick.
Cat Tree.zip (3.2 KB)
