1776wethepeople.c2d (1.4 MB)
Would someone check my pathing and speeds? and let me know if they are good? thanks shapeoko 3 xxl
Usually, when I have something I’m unsure of, I just run the cut in a chunk of insulation foam, trying to watch carefully for a plunge which is greater than Depth per Pass into an uncut area.
It seems redundant to have a pocket w/ a #122:
and then cut that same geometry with a V-carving:
Unless this is intentional to get the center cut at the bottom of the pocket?
If you have Carbide Create Pro you could save some time using a 1/4" tool to clear the bulk of the pocket:
and then using REST Machining for the balance:
One concern is you are cutting to a depth of 0.236" with a #122 tool, but per the shop page:
Cutting Length 0.063 in
so the tapered part of the shaft will run into things — you’d need a specialty “long reach” tool to cut almost 1/4" deep at that size.
My recommendation would be to instead cut with a V-carving to full depth for the details of the design:
Then cut the stripes using a Depth limited V-carve with Pocket Clearing:
which previews as:
c.f.,
(and you may want to review the preceding videos on Pocket and Contour)
Let me think about the engraved letter bit — that was a popular thing once upon a time (Goudy Engraved, Caslon Openface, et al.)
A possible approach for the Engraving effect would be to use a depth-limited V-carving for the letters which one wants cut thus as well, but to inset these letters:
Apply
and use Node Editing to clean things up:
d
repeating this wherever there is some errant aspect:
If necessary, select nodes:
and tap s to convert to Smooth
Eventually arriving at:
Done
Add the engraved text to the depth-limited V-carving used for the stripes:
Except that depth happens to exactly coincide with the inset text — either use a shallower depth or a more acute V-tool (we will do both), as well as a smaller Square tool:
Then select the inset geometry for the engraving aspect:
and assign a V-carving toolpath which starts at the bottom of the previous pocket:
i just tried to do all that the way you showed and it came out worse then the file i set lol
How deep should I do my flags? I believe I’ve been doing them to 6mm ot .236in
Upload the file which doesn’t look as nice and we will look into this with you.
How deep a feature should be cut depends on the thickness of the stock, the desired effect, and the tooling you are using.
I’ve been using 3/4 pine. I didn’t save it. I tried to follow each of your pictures, and my times were like 200 mins per bit path.Here’s 1 I retried
we1776.c2d (1.3 MB)
Why are you depth-limiting the two texts?
You are using a very small endmill to cut very large areas, hence taking a very long time:
and I don’t see the inset geometry as suggested:
Please find the file as described above attached:
1776wethepeople_v8.c2d (736 KB)
Note that it requires a 30 degree Amana V tool which I have described as:
You will want to test those feeds and speeds.
When reviewing toolpaths, the best thing to do is to disable all of them, then enable them one at a time working from top → bottom and carefully checking the preview as you go along and ensuring that a given toolpath doesn’t cut a region already cut by another tool.
I would especially recommend looking into using the V-carving w/ Pocket Clearing toolpath option. Formerly known as “Advanced V-carving” it has the desirable attributes of clearing large areas quickly, while making very fine detail work around the perimeter. Video on it here:
The alternative is Carbide Create Pro and REST Machining.
To expand on the above, toolpaths, like most things are a series of tradeoffs. For a given area:
One can cut with a large tool
and get it done quickly:
while having rounded corners:
(and if relevant, not able to fit into narrow areas/details)
or, use a smaller tool:
and take a very long time:
but getting into corners and narrow details:
As noted, using V-carving w/ a Pocket clearing option gets one the best of both:
@beatupsnyc I’ve noticed you’ve been asking a lot of questions on here about things like how to set up toolpaths and which bits to use and stuff like that since you’re just getting started. Have you thought about looking into 1:1 training at all? I don’t know if they’re any good, but I do see that CNC Files has a way you can pay to have someone work with you directly to learn how to run a CNC and everything. cnc-files
It might be a good option since it is a video call and would let you ask questions and get direct guidance as you’re getting familiar with using your machine and all. This way you don’t have to worry about the constant back and forth that comes with message boards
Note that Carbide 3D does this as well:
Well now I’m fine setting up and getting the cnc to work fine now its more just pathing.
Figuring out the paths, bits, speeds, feeds, etc, is still a big – and probably even bigger – part of the process. I’m just suggesting it because I’ve seen you post a lot asking for someone to check something, which bit should you use, why isn’t the star in a v-carve doing what you were expecting, how do you get an STL to look the way you want, Font questions, etc. It just seems like you’d benefit a lot from just being able to walk through some of this with a person who can answer all these questions in real time which would help you get more comfortable quicker instead of spreading the questions/answers out over hours or even days.
Folks learn at different rates and in different ways — it’s fine for folks to ask questions in a way and at a rate which they feel comfortable with — it’s also okay for folks to get training or tutoring.
@beatupsnyc I will note that if you want a more traditional learning approach, the community did work up:
and I did write up:
which are pretty basic, but which do go over the basics and concepts — the big thing is that there are multiple ways to approach a design and myriad tooling options and pretty much every one of them is a trade-off in some way.
For drawing see:
