I have my new Shapeoko Pro 5 setup with the 80mm spindle and the CW3000 chiller. The fluid lines they sent are blue. This means I can’t see anything moving through the lines. Everything is hooked up, and I turned on the chiller and it runs and displays a temperature on the front. The VFD cuts and does projects fine.
How can I tell the chiller is working? Is there a way I can monitor the temperature of the spindle? I can’t even tell if fluid is flowing to it
When I start mine up there are usually a few bubbles at the top of the curve where the lines come out of the spindle. When I turn it on I look at those bubbles to make sure the chiller is pumping.
Only way I know of to monitor the spindle is to stop it & feel it. Unless you have an infra-red thermometer.
My flow meter of that style ended up leaking at the seam after some time. I haven’t replaced it, I just removed it. I did buy a similar one to replace it but I would’ve welcomed a more robust design - haven’t installed it yet.
