I’ve been running a bunch of jobs recently and I’ve started to notice that my machine doesn’t seem to be cutting perfect circles like I need it to. Anyone know what might be the issue? Maybe I have to re-tension some stuff?
Check the gears on the X and Y axis motors They’re held in place by a set screw that should mate with a flat on the motor shaft. The set screws were loose and/or not lined up with the flats on a lot of machines. That will definitely screw up your circles among other things.
Tom
Please use the operating checklist: http://docs.carbide3d.com/article/41-machine-operating-checklist — it should help you to troubleshoot such things.
For the pulley set screws, please see: http://docs.carbide3d.com/article/169-shapeoko-3-how-to-check-the-pulley-set-screws
The amount its off by is definitely reduced.I may need to get rhe new z plate upgrade that was released after i purchased to stiffen up the router. Thanks for the help!
The z axis plate definitely helped improve the quality of circles on my machine. I’d recommend getting it.
