Is there any way to get the Finishing pass to follow a bowl-like hollow’s contours rather than being linear? I used an end mill for the roughing and those paths follow the contours. The finishing pass with a ball end created linear ridges. I realize the ball end will also create ridges but would prefer to have them concentric within the hollow profile.
Not in Carbide Create Pro.
I believe MeshCAM will do this/has such software controls for toolpaths (waterline might be the right term), but you’ll need 3D CAD model of your bowl.
In the process of learning Fusion 360 in order to have better control of this sort of thing. In the meantime, I am tricking CCpro to do what I need it ![]()
