Cleaning bits of Oramask residue
Hello fellow Carbide 3D users. So, we have recently (FINALLY!) discovered how to use Oramask correctly (turns out upcut endmills are really a very bad idea! A sharp v-carve seems to be the ticket. Go figure). Anyway, after only about 10 of our smaller signs, there is now a glue residue on my nice sharp bit. And my poor sweepy!! It’s hair is dyed blue!
So, any thoughts on cleaning the bits (first question)?
Secondly, any other great tips for a “beginner” using Oramask? The Finishing Lady has figure out how to have next to zero bleed-under, so that’s a huge win. We squeegee it down with a silcone thingamabobby, and also the hairy version of it.
I’ve never had an issue with oramask leaving glue on my endmills. I’ve used brakleen and a soft brass bristle brush to clean my endmills when I get 2sided tape residue on them. You could also try rubbing alcohol.
with tape & glue, I use a shot of WD40 on a rag.
I quit using oramask and started using adhesive backed shelf paper. However I use painters tape and super glue a lot and get the blue residue from painters tape on the bottom of bits. I use mineral spirits to remove all I can and have some CMT Formula 2050 blade and bit cleaner I keep in a 5 gallon bucket to clean bits and blades. I let the bits/blades soak over night and everything just wipes off.
You could use a brass brush to help clean stubborn spots but do not use a steel brush.
@gdon_2003
Thanks!! Why did you stop using oramask?
An update: so last night while carving an HDU sign, a small strip of oramask came loose, wound around the v-bit, thus creating a different “adjustable” profile, and dig into a couple spots on the sign. Repairable, yes. Irritating, even more so. The Finishing Lady ask if the bit was sticky. So, I guess another reason to clean the bits.
So, I added “Jenny” V-bits that are downcut bits. No problems with lifting mask material.
I’ve never used Oramask, because others on this forum have suggested the common ordinary shelf paper product I get at Walmart. Saves money; works fine. (Just don’t let it sit on wood for extended time; months. It will leave something behind.)
I use a roller device to press down on mask material. Less friction in thin areas.
I also use blue tape and super glue, then use roller device to press down on the still liquid joint. Glue sticks because it is a thin layer.
I also compensate my Z-zero for the blue tape and glue joint. Seems like it’s about 0.010”.
I have acetone around to clean bits.
ADDED: Soft Rubber Roller
ADDED: Shop Jenny Bits
ADDED: Duck Grand EasyLiner shelf liner white 20"x15’
I was concerned that any of the masking material would not work well with HDU. Do you do any special prep?
EDIT: ha, I just searched and found a post where I asked the same thing last March and you indicated sanding to 150 helped. Did you do some additional treatment to eliminate bleed?
I quit using Oramask because it is expensive. I started using adhesive shelf paper (vinyl) because it is cheap and locally accessible at Walmart. There are different types of Oramask but I found that the shelf paper works just as well.
@CullenS
Just asked the finishing lady the procedure. We are currently the oramask as a final paint color use. She does sanding of the HDU, priming, sanding again, 2 coats of paint, let that dry, ensure their are no “fuzzies” on the surface, apply the oramask, squeegee the ormask on.
When I get it in my hands, I squeegee again, then carve.
They will go after me with a coat of primer, 2 coats of paint, remove the oramask. Super sharp clean edges, with very minor touch up.
Edit: Here is how it looks after carving.
Edit #2: So, apparently after this is carved, she will apply whatever the color of the paint is under the oramask around the oramask. That way it seals any air holes and if some of the paint dies seep in, you don’t see it because it’s the same color. Then she goes back and primes a coat, then 2 cots of paint. Pull the oramask. And apparently next to no touch up. This is the brush she used for this first step.
https://a.co/d/0gmBAt4v
It was the first thing I tried (and I’m sure the other solutions work great too), but the rubbing alcohol worked great! Now a basic procedure before I carve is to clean the bit with 99% isopropyl alcohol. (Using this for cleaning my 3d printer as well).
I use one of these ultrasonic cleaners with Simple Green to refresh my bits after each shop day, and I find that the bits stay sharper and I have less risk of burnishing wood in sharp corners and such. The cleaner was a great addition to my shop.
@PaPaRoe
Thanks for the recommendation. Purchased! Full concentrated or diluted Simple Green.
Simple green is a staple in my shop. It is useful for a lot of things. I use it full strength and do not dilute it.
Thanks.
I am hopefully going to get some large signs to do soon. I am really not looking forward to the finishing. I would rather farm that out. It takes time and space.
Does your finishing department spray or brush the background post carving?
Brushing is the main thing she does.
She did say the KEY is brushing in that first layer on the HDU, as it has a lot of air bubbles.
She can “get away with” spraying the second coat with just a little if any brushing.
I use Simple Green at full concentration and the machine’s default run time, which I think is 30 minutes. I start it up, leave the shop, and the next morning I fish out the bits and use a bristle brush to clean off any remaining tar.
This is a great idea I’m definitely going to try the shelf paper. Thanks.
@gdon_2003 @CrookedWoodTex
Yup. I agree with @Jmcwoodworking. We ordered some too. Always worth saving money. And this community is full of super smart people!
And SirGariff would always be included in that group!
