I have a question on the 1.5 spindle and Cm. Using gSender i was able to enter gcode to start the spindle to a certain speed and pause at start of a job because it takes time for the spindle to get to speed and prevented the bit from starting the first cut before spindle was up to speed. Does CM have that capability.
You will need to add a “Dwell” command (which CM does automatically, and Grbl supports)
Thanks , how dow you do that in CM
Motion adds a dwell automatically for the spindle to get to the correct RPM.
Thank you. This community is great and very responsive
