Hey everyone, I have a request out with support but figured I’d see if anyone else has had this issue. I did not find this particular one in search though. I just wrote a new program this afternoon, got on a roll and save 12 different versions as each one has a different name engraved. I went to load one into CM and immediately get Error on line 2: unknown errors. The problem is that it doesn’t tell me what the error is so I’m having a hard time diagnosing.
I tried loading a file I ran earlier in the day with no issue. I went back into Carveco and examined and recalculated each and every tool path but still the same issue. I even saved files with just one of the tool paths each to see if there was a particular one causing the error but none will load. I have a large order I have to finish in the next day or two so any help/insight is appreciated!
