Work offsets last between powercycles…
Does CM use work offset 1? Or does it just track the offset inside the software and restore it when connecting to the machine?
Tried something out.
$#, and it looks like work offset 1 is back to 0/0/0.So I’m guessing CM does everything internal to the software. The only way to transfer to another program would be to go to the current X/Y/Z 0, reset work offsets, and then make a note of the current position which would also translate to the machine home offset. Fire up the other program (gSender, lightburn, whatever), move to that location, and set the origin/offset/zero to that location.
