CM5 sees my machine as a Shapeoko 3 instead of an XXL
I haven’t been on it for a while, and decided to fire it up today. I downloaded CM5, homed the machine, and when I try to jog to the farthest corner, it stops roughly in the middle. On the settings, it shows up as a Shapeoko 3 and not an XXL. I do not see way to change the machine type. Hoping it’s just something silly I missed.
Thanks
you can change that in the settings menu (right top of the screen)
Be sure to send the config. Once sent it will not change unless you change it. The configuration is persistent over controller reboots (power cycles).
Yes, I see it now. It’s the first option. I think what threw me off was the text box that said Shapeoko 3. I was expecting a dropdown there. Thanks for the help!
