CNCj driving Vertigo CNC router(good machine, NZ made by innovative yiung couple). Operation stops at random time during process. The project has suddenly dissapeared off CNCj screen.
Seeking advice - does anybody experience the same? Any suggestion why this happens? Thank you to everybody out there in the community
Hi Ralf,
Note that this is a Carbide3D forum, so you will probably not have much luck finding someone who uses that combination of CNCjs (which I assume is what you meant?) + vertigo CNC
If the CNCjs UI goes blank, you may have better luck posting an issue to their github ?
