My experience here is limited, but the only time I’ve seen the RaspPi act in a stuttering manner is when its power supply was inadequate. Plugging it in to a USB adapter with a higher wattage stabilized it in my case.
@Julien top is sorted by CPU% right? root and pi are the biggest users at 1% each.
@Gerry I’m using an approved RPi4 wall wart that has worked for ~1 year outside no problem. But yes I have experienced the little lightning bolt when I first set this up.
Hmmm… I guess it is always possible that the Pi hardware itself is having an issue. This is straightforward to test if you can find another Pi and stick your SD card into it. Possible?
I had the same problem, the Pi would typically lock when powering up Carbide controller, and choke during regular operation. Some kind of communications issue. Never did solve it, just plugged in another Pi. The original Pi works fine with everything else I’ve used it for. A number of references discuss USB issues with Pi’s, some hardware conflicts, as well as available firmware updates. I think it might have even come up on this forum at some point.
My Pi’s is are all in solid aluminum cases, the case is heatsink, no fan. And I don’t really cut any wood.
Flashing might help, I never tried. The original Pi(purchased when 4 came out) has been attached to a DAC via USB and running continuously for a year or more I suppose, and has never hiccupped. Shapeoko controller would lock it on power up.
As mentioned, there were some updates concerning the USB on the Pi4 if I recall. Might be worth looking into.
Okay but what about my test suggestions from earlier? What exactly happens when the Pi becomes unresponsive? We still haven’t really narrowed the problem down to the Pi.
