I was running a project with a 1/8" endmill in a contour toolpath on Shapeoko 5 Pro ,i put the bit into the collet to far
and the black screw and collet that tightens to 65 mm VFD got toasted and put a burn mark in the wood, need to order a new black screw with collet ,
does any body what size the black screw is with the 1/8" collet i need, for the 65 MM VFD spindle.
on the website the only one i seen was the ER 11-with 1/4" collet ,was needing the 1/8" collet
If you have the original 65mm VFD, then it has an ER-11 collet, and the one from the shop will fit.
If you have the newer 65mm VFD w/ ER-16 collet, then you should contact support@carbide3d.com
