I have a bunch of used endmills of various diameters—5/16”, 1/2” and larger.
Is it possible to get collets for the Carbide Compact Router that allow use of endmills larger than 1/4”?
elaircorp.com makes precision collets for a lot of routers including the Makita/C3d. They come in MM as well as SAE. I dont think they make any larger than 1/4 inch because the interior shaft size of the router. C3D is making the same router with an er-11 collet that may take up to an 8MM, maybe. You will have to do some research. Check out elairecorp.com for what they have. These are for the Makita/C3d Router.
| Elaire Part # | Hole Diameter | Makita Part Number | Price | Buy Online |
| MRP-1250 | 1/8" | N/A | $24.50 | |
| MRP-1575 | 4 mm | N/A | $24.50 | |
| MRP-1875 | 3/16" | N/A | $24.50 | |
| MRP-2362 | 6 mm | N/A | $24.50 | |
| MRP-2500 | 1/4" | 763637-1 | $21.50 | |
| MRP-3150 | 8 mm | N/A | $24.50 | |
| MRP-SET | Collet Set 1/8",3/16",1/4" | N/A | $63.50 | |
| MRP-SETM | Collet Set 4 mm, 6mm, 8mm | N/A | $63.50 |
For ER-11 Collets I found this size range:
| ER Collet | Length | Clamping Range |
| ER-11 | 18 mm (0.71) | 0.5—7 mm (0.020—0.276) |
I am sure you can also get SAE size collets for ER-11.
You can get a 3/8" collet for Makita style routers like the C3D one… but that’s a larger as it gets for the shaft size.
Elairecorp has the following statement at the bottom of the Makita Collet page.
" ** If you require a sizes not listed, please call or email us and we can accommodate
Collets are compatible with the following routers;
RT700C, RT0700CX3, RP0900K, 3621, 3621A"
The Elaire Corp. 8mm collet will work for 5/16" tooling (assuming the tooling is otherwise suitable).
The 3/8" collet is a tiny thing, and usually only used on a CNC for metrology gear.
