Community challenge #24: Elements (closed)
Yeah, the pinch force of the plastic isn’t quite enough to keep the coin from moving if the mill hits too hard. For the next version I’ll add a bolt that pulls the sides together.
There’s also a little bit of flex in the z and y axes. I need to beef up the plastic, or maybe use some metal stabilizing plates.
The end mill I was using had way too much flute length (I originally got it for foam board). The new mills I have coming are nice and stubby, so they should have less flex and be less likely to snap.
You could also sand 1 side flat and use the super glue painters tape method and not rely on plastic clamping surfaces. Or possibly spray the plastic clamp with hair spray and pop the coin in for extra hold. Then use rubbing alcohol to clean it between coins. You will need to get it kind of wet and let it dry a few minutes but it works on bike grips so maybe it will help here.
Alright, finished-ish project first.
Quick background time, I live in a underwater themed apartment dubbed “Poseidon’s Grotto”, the bathroom window in said apartment is lacking some privacy and could use a boost to the airflow. Cue the new Shapeoko!
After a quick mockup on Shapr3D of the overall dimensions I went to work with the actual design.
My idea was to repurpose the insides of an old window fan into a custom frame on one side, and some faux stained-glass (epoxy) on the other. Thus fixing both the privacy and airflow issues.
Awhile ago I had picked up some old oak flooring off craigslist that I decided to use.
I processed it first by running it through the table saw to clean up the edges.
I then jointed it with with my Shapeoko. I used my Whiteside 6210, with some help from the advice given in this post (feeds and speeds).
The wood was then glued up, and then flattened on the Shapeoko.
I think it’s about time that I learn how to tram my machine…
While the glue was drying, and the wood was being prepped I put together my design on CC.
I used the Flourishes_18, Sunfish, and Wave_2 elements. Now for the actual process, I had got so caught up in my Linear Algebra class that I forgot to take pictures from this step onwards… anywho…
Step 1: Pocketed out the fish, and corner flourishes leaving 1mm of wood as a backing. Then fill with epoxy. (lesson learned: I need smaller tools for more detail obvi)
Step 2: Vcarve (60 degree for the added depth) out the wave_2 patterns knowing that they won’t get revealed on the backside. Then fill with epoxy. Vcarve (90 degree for the narrow path) the inner details on the epoxied sunfish with a shallow depth. I’m pretty pleased with how that turned out. Although I did need to go back in with a knife to clean up the epoxy.
At some point in this process some of the epoxy soaked through and needed to be removed from the backside.
Step 3: I broke the design up into 4 quadrants to create a small ridge the ran top to bottom, and another left to right to give it a look of being held together with metal (as stained glass is). I Advanced Vcarved the four sections, and plan to paint the background a deep sea blue with black or copper for the “metal” ridge. (staining the rest of the exposed wood too for the full window into the sea effect)
Step 4: I flipped the bad boy over and pocketed out the epoxy allowing light the shine through (too lazy to re-measure everything, so I just made a large rectangle. I finished it all off with a quick sanding with the orbital sander, 80 grit to help diffuse the light, and to remove any over flowed epoxy. I did my best to stay away from the display side though (didn’t want to have to re-polish it).
Although it isn’t finished (hope that’s okay), I’m really pleased by how it’s turning out. I just need a little more free time…
Thanks for reading,
Wyatt
Sunfish Window.c2d (732.9 KB)
Cutrocket Link
Hi all! Got our Shapeoko Pro up and running Friday night after several issues. This was my very first project and went horribly wrong, but I learned a lot. I’ve been following the threads and see a bunch of first projects that are amazing, so I figured this might be a pick-me-up for anyone else out there struggling to learn how to use a CNC. Hope it’s ok that I’m posting a project that is going to be completely scrapped and restarted tonight!
I used the TX_Detailed.svg file to create the outline of TX, then out 2 Offset Vectors in the center so I can create a depression and to remove the inside. The goal is to have a picture frame of sorts that I can glue together. Inside of the outline, I am going to be making a Stained Glass piece of the MD state flag (my husband is from TX and I’m from MD).
Here’s a picture of it in-progress. As you can tell, everything went a bit haywire resulting in uneven lines, not everything being cutout, burn marks and lines in random places. On the bright side, I learned how to zero the machine and what to do if you pause or have to stop your project in the middle of it cutting out!
Here’s the “finished” project that will be repurposed for something else.
I’m going to try again tonight and will update if it goes smoother!
Hey guys! So I’d like to submit this entry, but, forewarning: I destroyed the project in the very last step… :confused:
My idea was to use the Carbide 3D vectors to make a clock design with a slightly different skull on every hour… I happened to have an old clock laying around with a neon blue backlight and a 245mm diameter piece of circular glass.
I used the Skulls category in the design elements page & picked my favorite ones. I recently purchased the Mc Etcher 120/90 degree dragbit pack, and was excited to find a fun use for them. I started by taking the clock apart, and masking the neon light with tape. I’m a spray painter by trade, so this was pretty easy.
I used rustoleum flat black to repaint the clock face. I used Carbide create to position 12 skulls at 30 degree increments. (360/12…) I’ll include plenty of pictures :wink:
I had a hard time using the default svg’s from the design elements page… I had to use the node editing function to make sure everything was closed & contained…
IMG_8808
Then I painted the clock hands silver for more contrast, and made sure my tool paths were alright.
I finished my design in carbide create, and used my pen-holder to do a test run on some posterboard to make sure the vectors looked alright. The pen holder design is actually what’s available on CutRocket: Simple Pen Holder by thefrenchwickler
I used my test run to position the glass face of the clock and started etching with the 120 degree drag bit:
I made sure to flip my image horizontally by 90 degrees so the etching would be on the backside. It looks better that way, trust me. :ok_hand:
After the etching was complete, I reassembled my clock.
However, I cracked the glass when re-tightening the screws.
Ughhh so annoying!
The project would have been “perfect” if it weren’t for the glass cracking. :frowning:
Oh well. Lesson learned? I still think this was an improvement to the original design! Now I just need to find another piece of glass with a 250mm diameter… :sweat_smile:
then it’ll be good to go! :metal:
Sort of finished project:
I’ll need to wait for the epoxy to dry and then sand it.
Here it is with epoxy:
Wood is wenge and is really neat but also quite splintery.
I’ve been making a few of these dice box things.
Started as a for fun thing, then got asked to make a few more, and I’ve got a bunch of wood laying around and a workshop that needs more space freed up so making these hex boxes has been a nice little endeavor. (Also design entirely inspired by wyrmwood)
Since I have a few of these to make I’ve been looking at jigs. Since the magnets are on…sort of opposite sides I can use that to my advantage and put 6 magnets in the jig and 3 of them will line up with either side of the box.
This allows me to put a chamfer on the box (and flatten it)
Then put a design on the box as well. I also was inspired by the recent post from Winston on instagram about doing mother of pearl inlay. But that stuff is expensive! So I got some cheaper plastic stuff to test out the idea.
Used some super glue and a hammer to push the parts in. Would recommend doing a slight inset to make that process easier.
That one needs more contrast so I’ll likely route out the outside area to add some epoxy with black powder as well at some point. I’ll try and post finished pictures tomorrow when everything is cured and then sanded and with finish on.
So this one was actually quite.fun. Usually just use whatever is being made for someone but this drove us to use our creativity within a specific set parameter. So this narrows things down for my brain and allows better focus. Gong through all the SVG files I came up with a few ideas. Drew them up and when I was lacking the proper endmills to execute some of the elements I chose. Normally that wouldn’t be an issue but it is currently… Some ppl… ugh… Lets not go there. ;( … anyways so, that led me to create a few more designs. Finally I had an idea that made me smile and went with it…
First I was looking in the wave elements and kept wanting to do something with this guy found here.
https://elements.carbide3d.com/category/waves/wave_15.svg/
After that I was thinking of a tiki riding the wave which I did put together but wanted more. So I kept looking and was thinking what can I do with the Jack O lantern faces?
Light BULB!! Star Fish go with this wave I’ve kept going back to.
So I went and looked at my choices and the ones that just looked like they wanted faces and already had their own personality where the ones I went with.
https://elements.carbide3d.com/category/starfish/starfish_16.svg/
https://elements.carbide3d.com/category/starfish/starfish_20.svg/
https://elements.carbide3d.com/category/starfish/starfish_22.svg/
https://elements.carbide3d.com/category/starfish/starfish_24.svg/
After Finding all of them I had to go see which faces they were wanting… Lol… Just gotta listen they’ll tell you!
https://elements.carbide3d.com/category/halloween_jack-o-lantern_faces/halloween_jackolanterns_10.svg/
https://elements.carbide3d.com/category/halloween_jack-o-lantern_faces/halloween_jackolanterns_17.svg/
https://elements.carbide3d.com/category/halloween_jack-o-lantern_faces/halloween_jackolanterns_18.svg/
https://elements.carbide3d.com/category/halloween_jack-o-lantern_faces/halloween_jackolanterns_27.svg/
After having all the elements downloaded into CC everything went pretty quick.
I layed out the starfish where I felt their motions made sense. Grabbed the corresponding faces for each starfish I had picked. After that it was time to start joining elements. Now while I’m creating a drawing I like to keep all elements in their original form just incase editing is needed later. So what I do is lay everything out and then make a copy off to the side and start doing my editing on that while preserving the original.
So while joining I primarily used Boolean Subtraction. Having created multiple layers of the starfish in order to get the desired results.
After the drawing is complete I like to add a little color in AI to get a foundation on what I might possibly do with paint later.
Ok now time to set toolpaths for v carve and contour to cut the pieces out.
Everything checks out and time to start cutting.
I don’t typically use very many tabs unless artwork demands it, I leave a small layer and cut on final pass just a few thousandths and am fine. If you need to use tabs do so. Files don’t contain any.
Ready to sand lightly with 220
Hit the side to give some more character.
Time for primer… Love this stuff, Dries quick and takes a light sand with 220 and smooth as can be.
241268048_345213337288896_8250300263925697060_n
Ready for paint
Well well maybe I should post more to Cut Rocket… just noticed the 3 files I did post have around 1,800 downloads… that feels kinda nice… Thanks Guys
I dunno why the project won’t publish on Cutrocket as of this moment. but working on it.
Here’s the link to the project. Probably was waiting for approval. Forgot about that. Thanks you secret ninja…
Thanks for reading.
Round 2 went way better!! They need cleaned up a bit, but definitely workable.
Also, this little guy kept me company while it was running :slight_smile:
Thanks everyone, this way to the voting booth
Sanded then put finish on it. Really digging it.
Nice job @ScottsdaleSteve Steve!
Went ahead & uploaded the design file for the skull clock to cutrocket. I spent a lot of time fixing the skulls, so hopefully they will come in handy for someone else’s project! Halloween’s coming up! :skull:
Cutrocket Link:
Skull Clock by thefrenchwickler
