Community challenge #7, 2019-2020 edition
Hi there!
To keep us all busy/inspired/creative let’s kick off the next challenge.
If the number of clicks on the link Rob posted recently is any indication, MANY of you now have a Carbide Create Pro license, and have had the opportunity to test it by now, so let’s see what you can do with it!
Challenge #7 is: “Showcase something you did with Carbide Create Pro
The rules for this seventh challenge are:
  • submit your entry in this thread:
    • you must use at least one Carbide Create Pro feature
    • you must include pics of the finished piece.
    • you must include the CC design file (so it shan’t include any licensed vectors/images/heightmaps…)
    • tell us about your mistakes, tips and tricks, etc…
  • you can post multiple entries if you want.
  • timeline:
    • deadline is set to April 30th, midnight PST (a little longer than usual, considering 3D jobs are typically fairly long to run)
    • there will then be 7 days for voting.
      • voting will be open to legit community members only, and the jury reserves the right to remove votes from “outsiders”, and will also break any tie.
Something tells me you are going to like this month’s prizes!
And some cool Carbide3D swag:
Ready, steady, go!
WOW you guys are upping the ante!
Sadly I am stuck 4000km from home (and most importantly my Shapeoko) so can’t enter this one either, but I will be creating something with CC Pro that I would have entered!
Fun challenge…
when CC Pro first came out I thought it’d be a great way to carve land marks, like vulcanoes:
but eventually that got too simple so thiniverse to the rescue
heartt.c2d (679.8 KB)
helens try 1.c2d (274.9 KB)
unfortunately the C2D file for Mount Hood got corrupted in an early CC Pro crash
tutorials for the heart cut: From STL file to Carbide Create (PRO) [screenshots included]
Awesome Mt St. Helens rendition @fenrus! Were you there in 1980 to see the big event?
nope… I can see it from my balcony but I only moved into the area in 2007 or so
Design complete. 1st from scratch design, 1st full 3D carve, all Carbide Create Pro and CM. Got a jpg of a Sword and Shield I liked and traced out the components. Modified to my liking and did a lot of Boolean. Imbedded a texture on the shield. Added the lettering. Roughing pass with 1/4 inch end mill. Finishing pass with 1/16 inch ball. Starting carve today. Approximately 18 hours…
Lots of lessons learned from the Create process. Pray it comes out the way it looks.
Be safe everyone! End of tele-work is in sight…
Nice! How large is it and what material to you intend on using ?
My paranoid mind can’t help but tell you to keep an eye on that machine during that very long cut. Did you go with the default/recommended feeds and speeds in CC ? I wonder if it would be doable/useful to limit the 1/16th endmill finishing to a smaller area, i.e. draw a contour around the “non-flat” parts, to avoid having to spend time “finishing” the flat areas on the left & right sides ?
Can’t wait to see the outcome!
Another lesson learned…good point, Julian. That would cut down a lot on finish time. Maybe I will go back and modify the finish pass after roughing.
I have a 16x12 one inch thick piece of mahogany. I slowed the feedrate down to 40 in/min.
Thanks, again, Julian. Finishing pass dropped from 15 hours to 6.5. Early enough to stop and redo the g-code.
I have to second Julien’s comment, Can’t wait to see the finished! The mahogany should really stand out for this design.
Haven’t used CC Pro enough to know if the finish pass options have changed, but with Vectric you are able to combine passes at different angels which has a similar effect to using a smaller bit. The caveat of course is that the finishing time can be doubled.
I submit the following for considerationSword and Shield.c2d (3.8 MB)
Most of the issues here were self inflicted wounds. Not rechecking my zero after stopping for the night, damage to the project during clean-up, learning how to correctly scale model height, and not having a well planed piece to carve .
But, first 3D and first CC contest entered:
CNC Iron Sharpens Iron
Finished with 2 coats of satin lacquer.
Dramatic lighting to show the detail in the shield.
I figured we’d have a bunch more topography in here by now.
I’m not entirely happy with how this turned out, but happy enough with it to post it. Also to share lessons learned.
Wall of text that you can ignore if you’d like:
I’ve wanted to do one but wanted it to be slightly different, or have another function as well. Initially I was thinking of taking a segment of the moon and using a crater to hold a coin (like the Apollo 11 50th anniversary coin). Eventually settled on the idea of making a feature light up. So I picked Mt Fuji as a test template since it has a feature that is singular without much else in the way (think about like trying to pick out the lake in crater lake and how hard that might be).
I picked out some walnut for the project since I had a bunch that was in a random size scrap box. Also had some cast acrylic that was 9.3mm thick that came from the scrap bin at the makerspace from a while back.
Grabbed the grey scale terrain from the website Winston mentioned in the video:
https://tangrams.github.io/heightmapper/#10.12533/35.4271/-220.9006
Cut it down in whatever paint program I had on Windows, then brought in the object in carbide pro.
I also made 2 circles. The first was a light channel. I didn’t actually measure but I envisioned getting a tea light type thing in there. Second circle was for the acrylic to be recessed in here. I’m sure I could’ve done math or something to figure out how large I actually needed the circle and how much of the mountain would be acrylic. Ideally it would look like the peak was covered in snow. But planning stuff out was not a mood I was in at the time, so we’re in guestimation territory.
So I cut out a circle of the acrylic:
Then I cut a hole for a light later, and recessed a hole for the acrylic in the wood:
Then I used super glue to bond the acrylic to the wood.This may have not been the best. Or maybe used a more runny super glue. This one is I think more gel like.
Then I setup different roughing paths in carbide create. The circle I used to pocket the acrylic used acrylic speeds/feeds, then used hardwood for the rest.
Here’s the job after like 5 hours of machining time:
Sprayed some poly on it. I usually opt in for boiled linseed oil so I’m sure the finish could’ve been applied better.
Put a light underneath (and of course the tea light I have is too big). Think it looks pretty good, though:
A few lessons learned. I think I’d like to do a smaller light hole, and make this a 2 sided operation if I were to do it all over again. Pocket a hole for a tea light and then punch through with a smaller hole to the top for the actual light itself. Smaller hole for the light would allow me to have the acrylic start higher up on the mountain, which I think would give the mountain a more snow peak look.
Also maybe would want to use a translucent acrylic instead of the clear. The clear acrylic has a very obvious line between the where the acrylic ends and where the wood starts.
I think this is a fun idea to play with. One of the other versions I’d like to do is New Zealand, where the islands would be the acrylic and the ocean would be a wood. There’s also room to glue two pieces of wood together and have the top layer of wood be the total height for the topography, which I may try next.
I also made the box size smaller to exclude the bottom middle section that had indents.
Mt Fuji.c2d (174.9 KB)
@4NineDesign: I think it came out great, love the texture on the shield. And the little imperfections go along quite well with the overall “rough” look of the piece. Not everyone’s first 3D job looks as good as this!
@Radiation: oh boy this does not help me put my Nomad craving under control :slight_smile:
Definitely an interesting approach and something to explore. When I use clear acrylic and backlight, I usually leave some space to fit a strip of white plastic diffuser (the ones they sell for LED strip lighting), to…well, diffuse light more evenly. Looking forward to seeing that New Zealand piece ! (as a 2nd entry maybe ? :slight_smile: )
I know you guys are not eligible to win the prizes, but let’s see some entries from:
@robgrz
@edwardrford
@Jorge
@wmoy
@Luke
@WillAdams
And @Julien
Did I miss any?
So I get confused by the licensed images… so I guess I’m asking is a free image licensed, and by saying no licensed images that means it has to be made by us, meaning no internet pictures or images… am I correct on this thinking I just don’t want to submit something that is not approved
Hi Travis,
You can absolutely use images from the internet if…you are reasonably confident that they don’t have a copyright or some kind of license that restricts their use, and makes them non-shareable. The tricky part sometimes is figuring out whether they do…
In Google images there is a filter for that.
One easy counter-example is the famous Star Wars calendar, or anything else Disney for that matter.
My point was mainly, if you are going to post a file which contains vectors/images you downloaded from somewhere, make a reasonable effort to check that it’s ok to use and share them (both to meet the forum rules, and to keep yourself out of trouble, should be the evil troops of Disney lawyers decide to raid the Shapeoko forum :slight_smile: )
Aaaaand…just like that, I’m triggered.
(I blame you for delaying the rest of my todo list items ! :slight_smile: )
Awesome thanks for the info. Greatly appreciated.
In the spirit of honouring @neilferreri’s dare AND hopefully documenting in the process how easy it is to do a simple CC Pro project, here’s my non-eligible-contribution-slash-CCPro-tutorial:
  • Ever since the announcement of the Nomad2020, I have had a severe case of Nomad craving, so I figured I would pretend I have one and use my Shapeoko to mill something small and detailed.
  • I stumbled upon a block a Renshape that had been collecting dust since I got it in a package from C3D in late 2017, so now was as good a time as any to use it! It’s about 5"x3"x1" (and I measured it to be precisely 73.7mmx124.5mmx25.62mm)
  • I created the project in CC, entering a stock size a tiny bit larger than the dimensions I measured on the renshape block:
jobsetup
  • I wanted to use this opportunity to try @fenrus wonderful STL to greyscale PNG heightmap converter, and random browsing led me to that 3D model I liked on Thingiverse:
  • In CC I created a rectangle of the same dimensions as the stock, to be used later as an outer bound for the greyscale-based 3D toolpath
  • I figured I would keep 10.62mm of stock thickness as a base, and make the 3D hand stick out by 15mm, and created the base 3D component accordingly:
  • I imported the greyscale heightmap of the hand, resized it by x1.2 for a better fit and set its height to 15mm above base:
  • I then adjusted the image position a bit (and yes, I cheated a bit and padded the image generated by the converter so that it extended over the whole surface of my stock)
  • which got me this:
  • Finally, back in the Design tab I added some text:
  • and created a 3D component from that text, 3mm above the base:
  • and got the final 3D modeling done:
  • I proceeded to create the toolpaths, first the 3D roughing toolpath using the outer bound, with a #102 1/8" square endmill (that’s 75ipm / 0.08" depth per pass and stepover):
  • Then a first finishing toolpath, using the #111 1/16" ballnose, setup for horizontal passes (0 deg angle):
  • Then a second finishing toolpath, using the same tool but setup for vertical passes (90deg)
  • Finally, I used a #122 1/32" square endmill to get the smallest details in the text, doing a simple outside contour toolpath:
  • I would not be using Carbide Motion this time (mostly because I have an unsupported probe that I wanted to use for corner probing), and I wanted to have to ability to stop and check things between the toolpath runs, so I decided to save each toolpath to a separate file. I used CNCjs and @neilferreri’s macros to still benefit from the BitSetter for tool changes.
  • Since I would be milling material from a stock of exactly the size I had setup in CC with no margins anywhere, I decided to cut a jig in MDF for positioning the Renshape stock while being sure that it would align perfectly with horizontal and vertical axes of the machine
  • I installed the Renshape stock using good old tape & glue workholding:
  • side note: I used just a few drops of CA glue for this job, as I did not want to risk breaking the piece of Renshape after the cut when prying it away, and since there would be very little forces on the stock during the cut anyway.
  • Quick check that my 1/8" endmill was sticking out enough from the collet to be able to mill 15mm of material:
  • I used my vintage BeaverCNC zero probe and @neilferreri’s touch probe macro to set zeros.
  • first order of business, 3D roughing with #102 1/8" square endmill. Renshape mills like butter, this is so relaxing to watch!
  • Here’s the piece after the roughing toolpath:
  • then I proceeded to the 3D horizontal finishing pass with the #111 1/16" ballnose
  • and while it was not really necessary, I ran the second/vertical finishing toolpath:
  • I ended up with this:
  • Finally, I installed the #122 1/32" square endmill to get the smaller details in the text. It always feels scary to see that tiny 1/32" endmill go down on the BitSetter…but it works.
Fininished piece:
There you go. Oh my, Renshape is so easy and satisfying to machine, I have a newfound passion for it. Shapeokos should ship with a few blocks of renshape for beginners I think ! Much more rewarding than everyone’s first cut in pine/fir.
I showed you mine, you show me yours now ! One more week to go to submit something in the challenge.
I thought I’d present you with a little project. I’d be happy to participate… (even if I don’t have all the cutters I need yet;)
