Ok, I will take a deep breath, it’s only posts in a forum
So, to @nlichtenberg and [oops I can’t remember for sure who posted the nice multi-layer duck?], if you feel like it could you please re-post your entry ?..
Wait! Maybe it was that duck that caused the system to melt down! It was the first one ever posted!
Thank You so much for taking the time to post. Your attention to detail and perseverance is a model for me to aspire.
I took a look at devCAD and WingHelper and found it very robust and it looks like they way to go if entering your RC rabbit hole. Hope you continue to post your projects.
I’m so glad the posts were lost. Those terrible things I mentioned about the French are lost… phew
One more RC short kit created! This is a smaller plane that a fellow club member wanted me to cut for him. It all came out nice, but I figured out that the little 1/32 bit cut depth is a little too short for the 3/32 wood. I’ll need to dig up something that has a little more depth of cut than the #122 CC endmill.
I would love an explanation of how you fit the motor / electrical side of this for the RC plane if you had the chance. Or let me know where I could easily find that information. I’m interested in building something similar now that I see your awesome work.
Oh no server issues are no good.
Anyway here is the Carbide Duck back from the digital abyss. I had some troubles exporting the DXFs from Fusion 360 into Carbide Create, but did include all .F3d, DXFs, and CC files in the zip.
CommunityChallenge#8.zip (2.7 MB)
The duck is back! Yay!
\o/
The best way to read up and learn about electric power for RC planes is via Ed Anderson’s online book “Everything You Wanted To Know About Electric Powered Flight” As you dig thru it you will also find a pdf version of most of the content. There is some science to the madness for a nice running system.
@SLabuta, I love these little guys:
I think they have 1/32" endmills in up to 1/4" flute length.
Planetary Gear
Made this on the Nomad, it’s quite small at 75mm x 75mm (roughly 3" x 3") so it’s a fun project to run on some scrap wood. I used some 1/4" thick maple, but the dimensions are not that important, you’ll end up with 3 layers once assembled.
I had to start by researching Planetary Gears, got lost in the math of trying to calculate gear dimensions, tooth pitch, tooth count, etc. Ended up finding an ~okay~ gear simulator here, mixed those results with some photos, and edited that in photoshop. Once I had the 8 gears (don’t want to use the word ‘designed’), more like ‘hacked’ together I then imported into Carbide Create.
The results where then tweaked, top and bottom holders were designed which resulted in this…
The design for the top and bottom (right side of the model) were constrained to what hardware I could find, pocket holes for the nuts and screw heads. I have mixed feelings regarding the use of tabs in this project. Assembly took longer because of the tabs, next time I will probably remove the tabs from the model and use lots of tape. However if you scale this design up to a larger size the tabs may be a better route.
Assembly was easy, in photoshop I was able to eyeball how the gears would fit, and had reduced the size of the six planet gears which resulted in a nice loose fit once CNC’d.
Planetary Gear.c2d (2.9 MB)
This may end up as my goto project to use up scraps left over from other projects. This entire planetary gear could end up as one planet-gear within a larger planetary gear… hmmm.
Oh boy, you are really not helping me put my Nomad gear lust under control.
Thank you for your entry !
Here’s the Rummikub set again. Thanks @Julien for the notification.
The number tiles are finished with color now …
… and while it wasn’t meant to look like that, I like how the color has found its way into the wood fibers occasionally:
Overall, I learned a lot of beginner’s lessons with this project. Most importantly probably that cutting pockets parallel to the wood fibres can cause very large fibres to tear out (at least for pine), so that I started to rotate the design or the stock in order to prevent this.
Here are the files:
rummi.zip (268.0 KB)
Regards
Nils
Thanks for the update @nlichtenberg. What you get in those color tiles is “bleeding”, i.e. paint/pigment finding its way into the wood fibers (some woods are more sensitive to this, depending on their grain). One trick to avoid this is to apply a coat of shellac/varnish/lacquer/anything transparent really, to seal the areas you just cut. Let dry, and then apply your paint, and sand like you did.
Yup, I’ve been there. Either cutting at an angle or using a downcut endmill takes care of that problem.
Very cool Nils, glad you reposted!
2.5 days to go before the deadline, don’t be shy and let’s see those last minute entries!
(last time, @duexx took the “last minute” concept very literally by submitting 3 minutes before midnight!)
I can’t believe @Vince.Fab asked that question but had nothing in mind
Hi guys, the project I’m posting today is the sole reason for buying my Shapeoko’s and modifying them extensively. I documented upgrading smaller so3 to linear rails and ballscrews last summer but never actually followed up on how it performs, so this is how the machine looks today and it’s been a real pleasure to work on.
This project is actually a product that I’ve been developing for the past couple months. Coronavirus slowed down the progress as I’m having difficulty finding a company that would manufacture carbon fiber parts for me, but the majority of machined parts are ready. What I’m working on is a motorcycle cafe racer/street tracker kit for a 05-08 Triumph Speed Triple. The objective was to design a simple but visually appealing kit that would allow for quick change of style, by simply swapping mounting plates with seat units.
The design was heavily inspired by ‘Confederate motorcycles’ giving it industrial look, but also making it fairly easy to machine on the desktop cnc.
Don’t know if it’ll count as two entries or just one, but I’ll post both products that are part of the same kit.
#1 Minimalistic subframe with interchangeable seat units.
All the parts could technically be redesigned to be cut on the laser, plasma, or water jet, but machining them makes them look much nicer.
At the end of the post I’ll show how they all look mounted on the actual motorcycle.
#2 License plate mount.
This will also use a modular design, allowing for either - mounting a license plate behind the sprocket, next to the rear wheel or extend all the way past the rear wheel. The second option also comes with the integrated turn signals.
Option 1
At the time of posting don’t have access to my workshop, so couldn’t take a picture with the actual license plate mounted in this location.
Option 2
Finally, this is how all the parts look like installed on the motorcycle.
And also the unfinished street tracker seat.
Sorry for some of the pics being pulled from the IG stories and other taken with some crappy cameras, but haven’t had a chance to properly photograph entire kit yet. Hope you guys like it. And if anyone would like to follow my cnc struggles my IG is: bk1photo
There’ll be much more cnc content soon.
Hi @BartK
Very impressive…I can only imagine the countless hours that went into this, it’s just beautiful and a testimony to why the Shapeoko rocks! (and you do too)
So it kills me to have to mention this, but I suppose you cannot/do not want to share the associated design files, which was one of the rules of the challenge
Is there part of it that you could share so that people could benefit from e.g. your toolpath strategy, feeds and speeds, etc? in the spirit of validating the entry.
Thanks @Julien
I honestly missed the part where we have to upload the project and the tool paths, although that makes sense. The only part of the project that I can create separate file for and upload so others can see my technique would be those clamps.
They’re slightly oversized to fit onto a carbon fibre tube and allow for adjusting the angle at which license plate sits behind the wheel. I can make a separate Fusion360 file for it. If that’s not enough then ‘ohhhh well, happens’ lol
I’ve been known to bend the rules before (and I’ve been called a pushover for doing it, ha!), so as far as I am concerned, if you do make the effort to share a sample file and tell us about your approach/tips to cut shiny parts, it will be valid. Since the entries will be submitted to vote anyway, people who think otherwise will be free to not vote for you
