Caros amigos e usuarios, estou iniciando no C.C., não sei como manipular o tamanho das fontes na opção TEXT.
Obrigado
To manipulate text in CC, in the Design tab, select the text you want to edit and a text Parameters window pops up. Type a new size in the Font Height box (e.g., 2 in or 50 mm) and click Apply and the edited text will update.
Please note that how text is sized has changed in more recent versions.
If you are using an older version, I would recommend updating to a newer one.
Muito obrigado, Feliz Natal
Muito obrigado, Feliz Natal e um novo Ano repleto de realizações
