Computer Display or CC
I am working on a cat urn for my daughter. I created the design and in simulation I see a lot of little white spots. Not sure if it is my computer/display or if CC will try to put those in. I changed material to several others and the white dots persist.
CC Version 876
tiberius_cat_urn_front.c2d (100 KB)
I’ve seen them at various times and thought that they were some sort of artifact of the preview calculation.
That they show up is one of the reasons I prefer the lighter wood previews where it is less noticeable:
I ran your file and did not see any spots
I get them too. It seems more noticeable with the display brightness turned up.
I got the box built and the upper and lower pieces fit in. I will glue up tonight or tomorrow. After the glue dries I will cut the top off. I bought a latch and hinges to close the box. Now to decide if I put the cat’s name on the front or the lid. I need to decide that before gluing up the box.
The box is .5"maple and I used my Incra finger joint jig to cut it out. Used my router table with a 1/4" bit to cut the top and bottom dado’s in the box. Used stop blocks to not cut all the way through on the side pieces. If I cut all the way through I would have to fit in some replacement fingers. The top and bottom got a slight 45 degree cut off to make sure they fit well.
I have a friend with a farmer’s market booth that I have things in. He had suggested I make some pet urns. This one has been easy so far so waiting for the other shoe to drop.
I decided to put the text on top. The front was going to be too short after cutting off the lid and adding the latch. Turned out well. The white spots in previous posts were just in the display and not in the actual project.
This is right off the SO3 after a stiff brush removed some big chips.
Here it is after painting the text and the outline of the cat.
On the right side of the text you can see a little bit of tear out. It was caused by grain direction. Cutting downhill on grain produces tear out. You can see on the left side there is no tear out. That is just the nature of wood.
I will try to get a coat or 2 of poly on the box top tonight so I can glue it up tomorrow. I like to get a coat or two of finish on an insert top/bottom because applying finish after glue up can leave an unfinished area that pokes out later.
The cat’s name is from James T. Kirk of Star Trek fame. The font is Final Frontier and is the font used for the original Star Trek titles.
Used my 6" x48" belt sander to remove the proud finger joints. Cut the lid off the box. Got my hardware drilled and mounted. Sanded to 220 and put the first coat of poly on. May get a second coat before bed. Some projects are more fun than others. This one has been easy but not fun.
To close the loop on our end, the white dots will be fixed in the next release.
Finished and ready to send.
Nice job Guy. Im sure your daughter will love it
