I apologize if this has ended up where it doesn’t belong.
I am running GRBL 1.1f and CM 4
I am calibrating the steps/mm so my SO3 will cut round holes and square pockets instead of oval holes and trapezoid pockets. I am entering the $100 and $101 changes to MDI and when i read back the log data I see the updated $100 and $101. When I read back the config data the change is default. How do I make a PERMANENT change to the config file, I want to change the default step size.
So if I am understanding you correctly I will have to calibrate my machine every time by changing the 100 and 101 before i start to machining so i cut accurate features? Is this correct?
If you want the machine to cut feature sizes more accurately, you would do this step once, and it should be persistent until the belts are adjusted or replaced or the board is reflashed or the defaults are re-sent.
