Bought a XXL from a friend, he never setup or used the BitZero. I followed the online instructions for installing - machine has a circuit board version 2.4e so I plugged it in to the port marked RESERVED.
My confusion lies in where to install the ground probe ring lug. The instructions show putting it under a screw near the USB port - my machine doesn’t seem to have said screw. That part of the online instructions appears to be for the low profile enclosure.
Thank you Will, I figured that out shortly after I posted. My other question is how to run the probe cycle. I am running build 542.
He gave me the original BitZero with the machine, but the probe cycle seems to be wanting BitZero version 2. When I try to run the probe cycle it wants me to position the mill within the BitZero bore (doesn’t exist) and then the probe cycle fails.
