Confused using advanced v carve
Set up tool path in advanced. Using v bit for sign. Checked box to use 201 bit first. Loaded file but when asked for bit wants v bit first. I thought I’d also using a regular bit it would be first. What did I do wrong my
Usually when this happens the #201 is too big to fit; n the flat areas. Try with 1/8 or 1/16 bit and check preview.
