Contour cuts, stopping where tabs are
Hi guys, I was wondering if anybody could help me figure out a way around this issue where my contour cut, putting an angle around the outside of my piece stops where there is a tab below it. And no, they do not hit each other. The depth of the contour is less than the tab.
Post the .c2d file?
What tool is being used for the contour cut?
Check the “ignore tabs” box on that path?
The ignore tab worked. Thank you very much.!!
