greg5
(Greg)
August 29, 2021, 8:47pm
1
I have a sign I’d like to make faint lines in. In F360 I would do a trace with a depth of 0.5mm.
I’ve done a contour in CC, with a #301 90 degree bit.
However the preview looks a bit odd?
Is this just a limitation of CC’s rendering of the preview or did I do something wrong?
Julien
(Julien)
August 29, 2021, 9:32pm
2
Yes, CC does not preview contour toolpaths correctly when selecting a vbit, the g-code is fine though
WillAdams
(William Adams (Carbide 3D))
August 29, 2021, 10:29pm
3
You would need to re-draw the areas so that they will be closed regions — only closed regions are properly previewed w/ a V endmill and they can only be used w/ a V carving toolpath.
system
(system)
Closed
September 28, 2021, 8:48pm
4
