New to CNC and just completed the coaster project in Jumpstart. Finished product has resulted in what looks like a step out on one side of each coaster and also one on opposite side of each cutout. Any ideas on cause and correction moving forward? Thanks
That looks like the material shifted during the process. I’m not sure how you had things secured down, but that would be my suspicion.
I had the same issue on my first project, and never again. The only thing suggested was that the material had moved (shifted to the side). I suppose it was possible in my situation and yours, but without being able to see your workholding, it’s hard to guess.
In addition to shifting, consider how the Max Depth and Depth per Pass interact — so if one is cutting to a Max Depth of 0.5" w/ a Depth per Pass of 0.125" so that four full depth passes are made, if one reduces the Depth per Pass slightly to 0.124", then an additional pass will be made which will only remove 0.004" of material, functioning as an effective finishing pass.
Welcome to CNC! The shifting diagnosis makes sense — I’d also double-check that the stock is fully supported underneath and sitting flat. Hope the next set of coasters comes out cleaner.
I agree with all other suggestions but would also suggest insuring stock is exact same thickness all around. I speak from experience on this one. ![]()
Thanks for the insights - I will ensure stock is secure and flat and give it another run.
