I have a Text that will not generated a tool path for a Contour with a Vee 60 tool.
The same tool and depth works with Advanced Vcarve.
I think they make the same profile ( without the AV pocket ) when cut.
Why ?
RonLogoZ.c2d (384 KB)
Thanks
Why ?
Thanks
I think that since you have set the offset to âinsideâ, there isnât enough room to fit the entire V Bit. Since itâs NOT a V Carve, itâs only looking at the full width of the bit. Itâs basically like trying to do the same cut with a 0.500" endmill - there isnât enough room for it.
Contours with V Bits are donât really make sense for âInsideâ or âOutsideâ, only âNo Offsetâ. If you have a V Bit and an offset, your best bet is to generate an offset curve, then V Carve the gap between them.
I get the same result if I set the depth to 0.005, so the tool would not go across the available width.
HmmmâŚ
The problem is some geometry is open (indicated by being magenta):
That geometry can only be cut with a contour toolpath.
Everything else will work with V carving (or Advanced V carving)
The Electrc text I did a âmanualâ pocket with an offset to create a raised panel look for the Pocket area.
I was trying the same concept on the âBeaudoinâ text. I had just the âBâ selected as a test.
That is TrueType closed geometry
The Lightbulb does have open geometry, so that is not done as yet.
It doesnât matter how deep it is - Contour cuts only look at the full width of the bit.
Your inside contour is using a 0.500" wide bit, and that doesnât fit.|
If you really want to do this with a V bit, then calculate how wide the bit would be at the depth you are cutting, then create a new tool in the tool database and say that the tool is that wide.
I can do that. Thanks !
