Contours currently assigned to toolpath
Im currently making a toolpath using the Advanced Vcarve option, When setting up the toolpath it says under the Contours heading the following…“15 contours currently assigned to toolpath” with a button underneath to “replace with current selection”.
What does this actually mean?
Do i just leave as is or click to replace the current contours…
Thanks in advance.
It means that the toolpath currently has 15 contours associated with it, and that if you wish for the current selection to instead be used for this toolpath, you have the option of clicking the button to assign the contours in the current selection to be used with that toolpath.
is this in pro 3D only? I have never seen this
No, this is a basic feature in Carbide Create.
Thanks for the information…
