Was trying to do some chamfer edges on pockets, but my test cuts are not lining up the contours with the pockets. To illustrate, this is a simple 3 x 3 square in carbide create with an outside offset vector with offset of .375. The first toolpath is the 3.3 pocket which works fine. The second toolpath is an inside contour for the offset vector which is 3.75 in carbide create. It comes out 3.732 and the 0.02 error shows up on the left. All cuts with #201, no tool change to help illustrate the issue.
EDC_CHAMFER_TEST._003.c2d (64 KB)
