Hello, I just finished building my Shapeoko 3 CNC. I can’t quite get my meter leads into the connector. Are the homing switches NO or NC? And is there a detailed documentation on the controller board? i wanted to add some more end stops. I suppose I can just splice it in, but was curious about the other pinouts. I coudln’t find much in the docs site.
Thank you
EDIT: OK, looks like I was looking in the wrong place (docs site). I’ll search here…looks like I should be able to find what I need.
My understanding is that it’s the closing of the switch which signifies contact — one can use a jumper to close the Z-axis switch so as to upgrade to 1.1 using the Carbide Updater which requires pressing the Z-axis switch.
