When copying a CC file selection of objects, would it be possible to have a feature where the original objects being copied with multiple layer assignments can be pasted to another CC file and have the layer assignments retained? I don’t see a way to do this now, and not have the pasted objects layer assignments all combined into a default layer. This results in having to recreate all the layer assignments.
A work-around is to save a copy of the file, delete everything except what one wants transferred, then save and import the modified file into the other file.
As Will states, I just save a copy of the file and get rid of want I don’t want or add more if needed.
Thanks Will, that’s fine as a workaround, but I would like carbide to consider my request as a future feature implementation. Since copy and pasting is a function widely used in CC, it would be a useful improvement to this function.
