However my workflows tend to only use the first two options. I’m curious if people have used the third “Import as 3D component” button and if they have an example of what they’ve pasted/created with it.
It would make sense that it would be a pro feature, since modeling (3D import) is a pro feature. No point in importing a model if you can’t model.
with Pro, it does come up - and - if you have a region selected, it does import the model into that space if you make that selection.
I’m not sure how I would handle that sequence…selecting the model first and then going back and importing it…it makes much more sense to import the model into the space you’ve created, using the regular import model command.
