Is there a way to copy toolpaths in Carbide Create? For example if I am cutting out a bunch of coasters, I set the toolpaths for the first one, but when I copy the first one to put more on my wood board it doesn’t copy the toolpaths just the lines. Is there a way? Seems tedious to have to set the same toolpaths many many times.
Brad
Rather than do this, my suggestion would be to do a step and repeat, either w/ a utility, or use a comm / control tool which allows G92:
- http://www.shapeoko.com/wiki/index.php/G-Code_Utilities
- http://www.shapeoko.com/wiki/index.php/G-Code and http://www.shapeoko.com/wiki/index.php/Communication_/_Control
Surprised there isn’t a utility for this.
If you find the above confusing and would be willing to share your file (post it somewhere, or e-mail it to me at willadams@aol.com ), I could work up a tutorial using it.
Thanks for the links, I guess I am finding it confusing It would be great to have a tutorial and maybe others could benefit as well, but don’t go out of your way. Which file would you want?
The G-code file, once you’ve proved it out by cutting an exemplar.
