Crash after bit change
How do you get carbide motion to lift the cutter all the way up when moving to and from the bit setter during tool changes?
I apologize if this is a duplicate discussion. When my machine is moving from the bit setter position to the work piece, it lowers the the cutter along z at the same time that it is moving x and y. In this case it completely ignored the rapid plane height and crashed into the stock.
I can’t find an option for this in carbide motion. Is it in the post processor?
Thanks in advance!
Sounds similar to this:
