Wrote this up for someone who asked after it — hopefully it’ll help other people:
(in Inkscape):
- draw the geometry
- set the stroke of the path to twice the desired width of the pcket
- Path | Stroke to Path
- Path | Break Object Apart
- remove the fill and set the object to have a stroke, delete the extra inner path
- duplicate the original geometry
- Path | Combine it with the outer path created above
- draw in the additional geometry in such a way that it can be subtracted from the above — you may need to duplicate the above several times. I did Path | Intersection
Created a page on the wiki: http://www.shapeoko.com/wiki/index.php/Inkscape#Manually_creating_tabs
