I have purchased several .svg files from Etsy. The files themselves look great; however, I am wanting to create a border vector? I have carve create Pro but it doesn’t appear to ahve the option…help is appreciated. Thank you.
WillAdams
(William Adams (Carbide 3D))
February 5, 2023, 12:19am
2
You can export the pixel image of the 3D model, then import as a pixel image for image tracing:
We just posted CC 520 to: https://carbide3d.com/carbidecreate/download/
520 includes a big new feature for us, Image Tracing.
[image]
You should be able to load a JPG or PNG and get a reasonable set of curves from it very quickly.
A few caveats:
Right now, it’s mono only so color images will be converted to black and white using the thresholds in the window.
We’re not optimizing for very small images so some will work well, others won’t. We’d recommend images larger than 500px on a side …
then adjust the traced vectors to match the 3D model.
Thank you, I believe I got it to work!!!
system
(system)
Closed
March 7, 2023, 12:06am
4
