I used InkScape to lay the hole pattern out on a spiral, then brought it into CC and added the game counter. The size of the pins meant I needed a fairly wide hole spacing (7.5mm), so I divided the blocks of 5 holes only with a line, no extra space. This is unfinished, so the lines aren’t as visible as they would otherwise be.
Holes were drilled using the included drill mill, then I added a small chamfer to each using a 90 deg V bit.
Came out pretty well for a first-time experiment. I did notice that the black pins don’t fit as well as the others, they seem like they are very slightly bigger.
Well done - I really like that unique design. If you want skinnier pegs so you can reduce the board size, I’ve bought from this place before: https://www.cribbagesupply.com. I bought them in bulk for a run of cribbage boards I made for friends and family on my Shapeoko.
I recently made a cribbage board. I had ordered a couple of the C3D cribbage kits. The pins for the C3D kit are round and not tapered. So the pins would not fit in the cribbage board I made. I ordered some pins from Amazon that are tapered. You got 4 colors, black, silver, gold and brass. I could not tell the difference between the gold and brass. Turned out well. I got my file from etsy and it was a v7 Carbide Create file that I had to modify slightly.
