Curve cutting issue
Spent most of the day on what was what I thought was a simple job. Cutting out curved block letters that should fit together. Issue I am having is that the cuts do not match my design. The curves do not follow each other. Tried doing a simple design test and have the same problem. Not sure if it is a machine issue my brain not functioning right.
Files created using VCarve Pro.
When the cut is finished, the arcs do not line up.
I think you want to cut on the outside, not the inside.
You know, That is the one thing I did not try. I did on the line and inside the line.
Be right back…
Well, just wasted an entire day. Outside tool path worked though I cant logically understand why. Looking at the tool path for the inside cut, it seems that it should come out right.
But I learned a long time ago not to argue with machines.
Thanks for the suggestion. I probably would have wasted another day troubleshooting.
Geez, now that I stare at the picture, it makes sense.
