while never had this issue before set up project in CC. set tool path cutter using 302. go into CM load file use probe everything is fine. Get ready to start and the cutter will not go down enough to cut mail holder 2.c2d (196.7 KB)
V carving toolpaths don’t work properly when the stock origin is set to the bottom — please change that to the top.
After the 5th time looking at the file I seen that after I had sent the request. Changed it n now working. Thanks sometimes you just have a memory loss. Thanks again
