Cutting Brass Sheets With Nomad 883
I know that Nomad 883 is capable to cut brass and copper sheets.
But I still have some questions about the machine before I click the order button.
  1. Can Nomad 883 cut brass sheets with thickness from 1.5 to 5 mm?
  2. How much time does it take if I cut a disc object (8 cm diameter) out of 1.5 mm thick brass sheet?
  3. How much time does it take if I cut a disc object (8 cm diameter) out of 5 mm thick brass sheet?
  4. Do I need to standby spraying coolant during the cut in above situations?
Please advise. Many thanks :smile:
One comment about “copper”.
Be sure that you are not cutting copper alloy that has Beryllium in it. Beryllium is dust is quickly damaging to ~5% of the population and nasty and damaging to all.
@mbellon Thanks for your comment :slight_smile: Will get stock materials from reliable sources.
