Cutting Depth Question
Hello! New here. Hoping to invest in a 5.1 pro soon …?
Newbie cutting depth question - do you guys think this machine can handle a single pass of 7.5mm (.295”) with an 1/8th end mill @ 30-40ipm? I cut into hard maple end grain, and would probably be upgrading to the 65mm spindle.
My Makerspace’s industrial machine can handle this fine, but have no clue if a smaller machine like the Shapeoko can handle these depths.
Any help would be awesome!
Thanks
I expect this would be fine so long as the cutter could handle the cutting forces. That said, I don’t own a 5.1 so I’ll defer to folks with first hand experience.
@Archie
I have a S5 Pro with the 65mm ER11 collet. The S5 Pro has more than enough power to do this, the weak link here is the bit based on my experience.
Awesome! Thanks guys for the input.
I’ve been running this setup for a while, no broken bit yet
