Cutting issues with straight cuts
I have problem with cutting, if I cut a circle for example it leaves a small bump where the cutter steps in for the next pass. This happens even when there are no steps just a straight downwards cut.
Which machine?
What tooling?
What material?
At what feeds and speeds?
Could you provide a photo and the matching .c2d file?
Another consideration is Climb vs. Conventional Milling and tooling engagement — where possible avoid slotting and add geometry and cut as a pocket
and/or
