I would suggest adding geometry and cutting as a pocket — where possible avoid slotting and add geometry and cut as a pocket (Making vacuum hose adapters and/or Adding geometry to cut as a pocket with a finishing pass ) and consider leaving a roughing clearance and taking a finishing pass.
I will check on those things hopefully tomorrow. I did adjust my v-wheels and I “think” they are ok now. I am cutting on birch plywood. I will be mostly using that and pine. I was told (on here) to cut on better wood and that’s why I have to sand a little. I am cutting pine and birch for a reason, all of this is for bunnies and those are safe materials for them to chew on. I’m not sure if I have a scrap of mdf, but I can check to practice on.
I really do appreciate the help. Sometimes I first read the comments and I’m like… WHAT? So then I have to really read it and take my time. This CNC stuff is so new to me. I do love this machine though! Lots of fun bunny things to make!
if you hate the sanding of the edge… look into downcut endmills…
I recall when I began my journey into CNC hearing about compression bits. I thought hmmm, how does that work?
Compression bits are great for full depth - full thickness of your stock - finishing contour cuts. The idea is you cut your project slightly oversize, say 0.05 to 0.5 mm larger then you need, then use a compression bit to trim this excess off and consequently remove any fuzzies top and bottom.
I checked all the v-wheels and a couple needed tightened. Thank you for being so descriptive! I am going to see about picking up some mdf and maybe some hardwood tomorrow. Any specific kind I should look for?
I will look into compression bits too.
I picked up some mdf today. I did this test cut of a circle and square as we talked about before with no offset. I did a contour path using a #102 1/8 bit.
stepover .118
depth per pass .05
plunge rate 29.5
feed rate 59
rpm 10000
max depth .03
Should I cut is as a pocket path?
I’m sorry, what does step-down mean?
Does this mean max depth?
(since @jepho is temporarily busy having dinner )
It’s another word for “Depth per pass” as it appears in CC’s tool params window:
Yes, 2.54mm would be the “Max Depth (D)” field in CC
Thank you, I feel dumb with all my questions, but I want to get it right and understand.
I used the settings you listed. Thank you!
Thank you for all the time you’ve been helping! How does my cut look? To me it looks great, but…
Thank you, I bookmarked that and will do some reading. I’ll keep working and learning! I’m sorry to say you will be seeing more of my posts I’m sure! lol
You have helped me a lot and I really appreciate it.
This is precisely what this community is here for, so by all means do ask any and all questions (and there is no such thing as a dumb question as far as I am concerned)
The only thing we will ask in return are pics of cute bunnies !
I could overload you with pictures of bunnies! Brand new babies have just arrived!
They do get cuter as their fur comes in!
Shoot Girl they be cute now!!!
I took my dog to the vet yesterday. A lady had a laundry basket FULL of 1 month old puppies. They were all nestled to gether and so cute.
